type S cams
    type S cams
    I have a jdm h22a, will typeS cams improve my performance? Cb7tuner member "flatline" was talkin about that, so I'm curious.
    VTEC DUDE!!!!!!!
    Yes they will improve your performance. Those are the cams that cam in the 220hp versions of the H22. You can also get the F20B cams, which are the same as the Type S cams. It will have to get a tune though to get it to run right with those cams.
    "The Turtle"
    DD/Trail Rig/Mud Bug
      Originally posted by 93F22A6 View Post
      You can also get the F22B cams, which are the same as the Type S cams. It will have to get a tune though to get it to run right with those cams.
      The F20B has the cams that are the same as the H22A Type-S.
      And please, for the love of God, type like a human being!
        My bad hit the wrong key, edit fixed
        "The Turtle"
          Are they from a japan, cuz I thought all the american h22 only had 190hp
          VTEC DUDE!!!!!!!
            And how can I tell if they r typeS cams. Is there a visual difference?
            VTEC DUDE!!!!!!!
              I suggest you do some research on them..These cams are more aggressive than Crower Stage 2 cams...You can't just simply slap them on a stock head, because you will start breaking things..
              Search Type-S cams on HT, or Google, or whatever, you will see what I mean..Type-S and Euro-R stock heads are not the same as normal H22 heads..
              In conclusion, yes they do add power because they are aggressive, but you need to do some head work on your motor before it is ready to receive these cams. Good luck!
              Ronald
              |~~~~~~~~~~~~- Project CL1 Euro-R continues -~~~~~~~~~~~~~~|
                F20B auto and manual are different too.
                Click sig to view MR thread
                Links to other rides:
                Honda Accord Euro-R
                Honda Odyssey Absolute
                Honda City I-DSi
                Honda Stream
                  h-t is your friend
                  Purchased from: 90-JDMCB7, cb95spd, 92_dr_p, ukaccord92, slammed4thgen, 93a-lude, h22anow, cb7addicted, H22WAGON93, tonymontana1204, agol, Joshy
                  Sold to: di2accord
                    Ronald
                    *** I hate googling car stuff cuz it always sends me to other forums........
                    VTEC DUDE!!!!!!!
                      Ronald
                      I don't know how aggressive Crower stage 3's are, but Type S aren't that much more aggressive than stock H22's. I know because I've tuned 2 different cars with them with otherwise stock engines(one h22 and one F20B).
                      You CAN run them with stock valve train. However, with the stock valvetrain, you won't have the reliability of revving all the way to 8k without worrying of breaking your shit.
                        I was doing my research last month, and here are some of the quotes I found that stopped me from slapping on Type-S cams..
                        Originally posted by H-T
                        "...i saw a dyno of tuned JDM h22a cams vs. tuned type s cams in the same motor and it was less than 5hp difference at any point, even at peak......any stage 1 cam w/ tuning would give you more for your money.......and the type s cams will wear prematurely due to slightly different points of stress on the core itself.....sure, it's round and spins but it's being pushed from a slightly different angle by the valve stem as well and from what i've heard from smart guys, they will wear, cause the valves to go out of adjustment, etc..."
                        "...i thought that the euro R cams and they type S cams were nearly identical.. and the type S cams were more agressive than the skunk 2 stg 1's... i saw a website where it had all the cam specs, and i thought that the lift on the typeS cams was equivalent of a crower 2 cam.
                        edit.. i found the site, here..
                        Stock
                        Specs from H22 JDM Spec Type S
                        Advertised Duration *Duration @ .050" Gross Lift w/1.55
                        Int- 309 mid Int- 230 mid Int- 469 mid
                        Exh-315 mid Exh-230 mid Exh-438 mid
                        Crower 2's.
                        Int- 311 mid Int- 255 mid Int- 468 mid
                        Exh-308 mid Exh-248 mid Exh-467 mid..."
                        And another one..
                        "...Re: what is the type s cams valve adjustment specs and can the cams be used with stock valve springs
                        I would not try it. unless you stay well away from redline. lift on the type s intake cam is about .475 or 12mm. that is more than crower stage 2 which recomends springs. Try it and see. but post the nasty pics when it blows up, we all love that so much. if you have the engine and head all apart spend the extra $150 for titanium retainers for a little assurance but I would blow the $250 for springs...."
                        There are many more, but I couldn't seem to find them at the moment..But the posts I found were either posted by ppl giving advices saying NOT to install Type-S cams on stock H22 head, or ppl who already installed these cams on their stock motors and saying that they found metal shavings under the VC not long after they installed the Type-S cams, and that they ended up having to replace the cams, rocker arms, and other things..
                        If I remember correctly, H22 Type-S and F20B heads are designed differently, and they also have different valves, valve springs and retainers? Please correct me if I'm wrong
                        Hope that helps and good luck with the decision!
                        Ronald
                          They might, I don't know for sure because I don't care enough to research. But I do know you can install them and not run into any problems.
                          The oil you use is pretty important in rocker wear though. High zinc is what you need.
                          But just because you can do something doesn't mean you should. I would never use type s cams in my own h22 without using the valvetrain from it.
                          I wouldn't use type s cams anyways.
                            I'm getting a really good deal on the cams so I'm gona buy them, ill get the required valvetrain before I install them. It sounds like they r really aggressive wich I like!!!
                            VTEC DUDE!!!!!!!
                              Yeah if you upgrade your valve springs and retainers you should be okay..
                              Based on the specs, they do sound aggressive...But then, like Jose said, turns out they don't have much gain over stock H22 cams...Not just Jose, many people who have installed these swear that Skunk2 Stage 1 cams will make more power than these Type-S cams with little to no effort..I honestly don't know why..But I do know that Type-S heads and Euro-R heads are designed slightly different..And I'm not just talking valves, springs and retainers..
                              Like I said, I suggest you do more research on it..Just because they're a good deal doesn't mean they're worth all the hassle for less than 5whp gain..
                              But in the end, your money, your car, your decision..Good luck with it!
                              Ronald
