I have a question:
What kind of methods did you use to tune your map to a good AFR for all gears?
Since the RPM's and VAC would be the same in each different gear, and the load of the engine changes, is there a way to read the Engine Load Detector sensor to do some on the fly manipulations to the fuel tables? or somehow get it to compensate for the change in engine load?
