Has anyone put a cold air intake on an ABS equipped Accord? Seems to me the only way would be to re-locate the ABS components (not sure if that's even possible). Is my only choice a short ram?
Cold Air
Originally posted by CB7 Fanatic View PostHas anyone put a cold air intake on an ABS equipped Accord? Seems to me the only way would be to re-locate the ABS components (not sure if that's even possible). Is my only choice a short ram?
Originally posted by AbsurdNY View PostI'm not sure if the ABS would be in the way as I don't have ABS on my car but, you should do a ABS delete if it is.
For the OP, I have ABS on my coupe. As i have yet to put a motor in it, i'm not 100% sure it WILL fit. Looking at my sedan without ABS, it seems like it will. If it doesn't, i can get one made for you. I would just have to talk to my fabricator. I'm sure it can be done.
A CAI will fit with no problem.....check my sig or ride page!
The ONLY issue, is a 3" CAI from a prelude will be VERY tight (I'm currently trying to figure out how to install one)
But any CAI you buy for the accord is about 2.6" and will fit fine!My Member's Ride Thread
Originally posted by 19dabeast85 View PostA CAI will fit with no problem.....check my sig or ride page!
Originally posted by CB7 Fanatic View PostCan't see the ABS components in your sig.
I had an AEM 3" CAI from a Prelude (92-96) in my car and it BARELY cleared everything. The only thing i had to do was enlarge that hold near the bottom of my fender, since I had the accord 2.5" intake in there before, the prelude one is obviously bigger. But yeah, a little twisting of the pipe and it snugged in there. I didn't even have to move the battery at all.
here's how it fit in my car:
clears everything, ABS reservoir, strut bar, and the transmission kick down cable (since I'm AUTO) still functions perfect.
