Stainless Steele Clutch line
    Those who have this, what are your thoughts on it. Do you like it? Dislike? Please be specific with your responses! I am considdering buying one.
    Thank!
    theres no real benefit of having it. i just frees up alot of clutter in the accord engine bay because of the clutch diaphram. i ordered the same shit for chrisisiced. so ask him. i also have it on civic. no difference in pedal feel. it was just easier to bleed
      Thank!
      where are you going to get it from?
        Well if it doesn't feel any different I May not get it now. I was looking at TAS
          you know i was going to order one from TAS also and a lot of my 5spd conversion parts are new.. i might as well get a SS line also since it's only 10 bucks more.
            stainless steel lines are good because they don't degrade. Good for brake lines...but mostly folks use them (that I know) because you can re-route them wherever you like.
            hmmm...how would this work with fuel lines? Granted that the size would need to match along with making the proper connectors...
            ____
              exactly. taking a heavy beating is what they are good for. most people i know who get them have upgraded their whole brake setup and usually do it for auto-x or something of that sort. not really meant for drag racing or street use
              maybe unless you got a high power cb..then thats different lol
              no
              Accord turbo kit under $2k here
              $30 HID kits here Thread
              "What a selfish bitch. She looks like one too. A smart-mouthed, facebook-ing, "i dont know if im straight, bi or *** yet" little brat." -greencb7inkc
              "No Herra Frush, Slammed, tucked or frame dragging here. I'll leave that to the mini trucks...." -fishdonotbounce
                I'll get one no matter what! its better than those stock cheesy ones.
                Originally posted by toycar
                Braking the bank, maybe. Feeling like a boss, likely.
                  the one from TAS is a replacement part section of rubber hose to connect the clutch master cylinder to the slave cylinder. the one that i got is from the clutch master to the clutch slave cylinder. i use the line for street use. theres no pedal feel at all. the best thing about is that you can hide it anywhere.
                    Originally posted by oneoffaccord View Post
                    the one from TAS is section of rubber hose to connect the clutch master cylinder to the slave cylinder. the one that i got is from the clutch master to the clutch slave cylinder. i use the line for street use. theres no pedal feel at all. the best thing about is that you can hide it anywhere.
                    hold up say that again? they are both from the clutch master cylinder to the slave? i know TAS carries both, the SS and the rubber one which is ten bucks less.
                      TAS does make the whole line from clutch master to clutch slave. they only make it to replace a rubber section. i have the whole line.
                        huh?
                        they make the whole line, OR they make just the section, OR they offer both, which is it?
                        And, where did you get your whole line from?
                        1990 accord Honda-Challenge, H22 powered
                        newer race video,older race videos
                        1991 accord parked, parts and back up shell
                        1993 accord acquired 6-11-16
                            i should call and ask if that connects to the dampner or does it bypass it. better yet i should just make a reply to TAS's thread.
