Just curious, how long do you guys think the Royal Purple Oil combined w/ a K&N oil filter will last? Would it be okay to run it more than 3K/3months? I was thinking at least 5K.
How long of an interval for Royal Purple and K&N oil filter?
97' Honda Odyssey 199k miles...$485 spare van for my parentsTags: None
Originally posted by wed3k View Postyou could probably do 7500 and do oil filter changes at every 2500.
Originally posted by Losiracer2 View Posteven on the K&N filters? I thought they had more filter media so they'd last longer?
that applies to air intake filters only I'm sure^
I'd follow the max interval in the manual for oil, like wed3k implied, and 3k for the filter
I found this web page was relevant
Oil Change Intervals
Oversized filters offer you the chance to use extended drain intervals with your motor oil.
Honda recommends that you change the oil in your Prelude every 7500 miles. Many dealers attempt to get you change the oil in your car every 3000 miles. Changing your oil every 3000 miles is basically a complete waste of your money, and bad for the environment. (That used oil needs to go somewhere...)
Even the worst of oil filters will last for 3000 miles without any problems at all, and almost any motor oil will last for 7500 miles.
If you use Redline, Mobil 1, AMSOIL, Royal Purple, or Valvoline synthetic motor oils you can easily run your oil in your engine without any problems for the OEM recommended change interval of 7500 miles.
The only time you have to consider changing your motor oil at shorter intervals is if your car is not a daily driver, and will not warm up to full operating temperature for at least 30 minutes a day. The reason for this is that small amounts of moisture (water) in the air tend to soak slowly into your motor oil. (The oil system is not truly closed, even though you have an oil cap.) The water mixes with the oil and other matter in the oil system and forms acids that can eat your engine parts over time. Warming up the engine causes the moisture to leave the motor oil. If you are changing your oil every 3000 miles (because you drive the car once a week) or at a specific time intervals (every 4-6 months because you aren't putting 3000 miles on the oil), then it's not as import to use synthetic motor oil.
Some people will disagree with the above, but the fact is that just about every brand name non-synthetic oil (or "dino") will last 3000 miles and have almost no significant wear to the oil or engine. It is not cost effective to use synthetic oil if you car sits for long intervals with low mileage.
The chief advantages to using synthetic motor oils are typically considered to be better at extended drain intervals, have better thermal stability, better cold flow characteristics, superior additive packages, and a lower coefficient of friction (resulting in lower engine wear and better gas mileage).
Originally posted by customchord View PostI thought K&N said there filters are a million miles you just have to clean them so often.Last edited by Losiracer2; 09-10-2008, 04:45 PM.
Originally posted by dbsharp View PostI'd change the filter at least every 5k miles. The oil will probably still be good in 12-15k miles, but its your call as to when you wanna change that. bobistheoilguy.com is a good place to go.
I went to 4.5k on royal purple and a fram, oil was still relatively clean. No chunks or sludging.
That K&N filter is HUGE! I run a tiny little HAMP now lol.Originally posted by deevergote..It's not cheap to build a fast CB7, especially NA. However, if you're willing to put the money into the car, it's well worth it in the end. There ARE faster cars out there, but some people, like me, want THIS particular car to be fast!...
1993 H22A cb7 <3 miss you
04 WRX stg 2 sedan
Current - 02 WRX stg 2 wagon
Originally posted by myk View PostI went to 4.5k on royal purple and a fram, oil was still relatively clean. No chunks or sludging.
you think that would be wise?
7500 seems long to me, I might consider running my oil to 4000 miles now that I am completely switched over to mobil 1 and mobil 1 filters. I do it at 3500 miles now. but i would probably never consider goin past 5000 miles on an oil change, thats just me
all in all synthetics FTW
-seanMembers ride 15.927 @ 86.76 (f22a1)
Hit the clutch Hit the gear Hit the gas and i'm GONE>>>
Arcadia Green Crew #10
