Mods to start with
    Mods to start with
    Hello Everyone,
    New to the board and I have some questions about mods to start with.
    I asked my mech. if port and polish is a good thing and he said that the head of my car is probably a alumin one. So that maybe out of the question. But what else can I get other than Intake and exhaust?
    I want to get better gas milage for one but a little bit of speed power for another. Any ideas?
    T.I.A.
    S^2
    Running a 16yr old wagon and still loving it.
    just start with the basics: intake, header, and exhaust.
    are you planning on keeping this engine or doing the h22 swap? i wouldn't dump all this money into your F series engine if you plan to swap, but if you keep it just start off with bolt ons.
    you can also check out the phenolic spacers that i'm selling for pretty cheap.
    http://www.cb7tuner.com/vbb/showthre...threadid=11247
      Re: Mods to start with
      these two dont belong in the same sentence gas mileage and power, it's like mixing oil and water they just dont mix
      My Ride
        wELL, I'd like to do a swap but
        One: I don't have the money to go and get a motor and play with it.
        Two: it is a bit of a pain to find a h22 around in my neck of the woods.
        Three: I 'm trying to work on finding a house and so on down that road...
        So I am looking at just some things to do with the motor that I have now
        So carry on with the info.....
        S^2
          In that case, just do the things I stated above and you'll notice a little difference.
            cam, cam gear, advance your timing......
            just some ideas
              You can just go to hmotorsonline for it if they are too hard to find they can just ship it to you thats all.
                I'd say don't go for the power but rather put the power u have to the wheels. Clutch, flywheel, and some sticky tires. All are transferrable between the f and h series trannies if u do decide to ever swap i believe
                  I say go for the power then go for to what can help aid that power gettin it towards the ground. They both go together.
                    i made the same mistake...should have gotten the clutch and tranny stuff done b4 i turbo'd. Now i'm getting so much torque that the clutch just spins out most of the power that i should be getting to the ground. Its so bad i can't even chirp the tires in 2nd gear cause the clutch is too busy spinning
                      thats differnt it depends on what you get if you go forced induction you have to get alot of stuff for allmotor its not that serious but one with the other is like icecream without the cone. One without the other just doest taste sweet.
                        well its up to him now and i still say get the power to the ground first. But for power mods i agree as far as i/h/e/cam/and camgear but i'd like to add a fuel pressure regulator to that mix.
                          Thanks Guys for the info,
                          Though I may of have found a junkyard that may have some H motors in their mist of cars. And this junkyard lets you pull the stuff yourself, which I like to do but maybe not on the motor though.
                          Question though about the motors...How much should one spend on a h motor? I haven't a clue to this means, and I don't want to get hosed over either.....
                          Thanks once again.
                          S^2
                            The most important mod is the adancment and skill of the driver. How long have you been driving your cb7 and how often are you pushing it to its limits?
                            To have loved and lost is better than to have never loved at all #CB7Life
                              In regards to SoySauce:
                              I have had the car about a year now, It has little over 151k on it and It seems to run pretty strong IMO, AND best of all it is a 5 speed wagon which is a pain to find in my area since I favor wagons. I really don't redline it, just usually shift at 5000 - 5500 in the first three gears If I can. usually up to about 70 or so then so I can't really get it up to the Higher RPMs then or the boys in blue will come and play along with me. I believe that my spark plugs seals or gaskets on the head or so on need to be replaced since the one plug has oil on its tip. Other than that I love the car. I had been waiting to get one for some time now.
                              S^2
