Good condition radiator cap that actually works, is key as well.
Redline Water Wetter
Originally posted by TypeG View Postwater wetter was made to be used with water only, it says this on the bottle.
personally, i would just use a 50/50 water and coolant mix. later.
So idk, I live in AZ, where it gets HOT in the summer.....almost near death valley temps hot. And cold in the winter but not below I'd say 35*. I'm just looking for something that'll cool my car better. My temp needle seems to fluctuate to 3/4 sometimes, making me weary of stuff.
Originally posted by HondaFan81 View PostGood condition radiator cap that actually works, is key as well.
Originally posted by mozzandherb View PostWater Wetter and the Royal Purple additives are crap, you might as well just add some dishsoap in your rad, it's basically the same thing. Shake a bottle of water wetter and you will see how it bubbles up. There is a product that has proven results, it's called Silkolene, I haven't tried it yet, but I will be.
Water weter works by increasing the water's surface tension so that it can effectively absorb (and dissapate) heat much more efficiently... Its NOT simply soap and thats one of the most ridiculous things ive yet heard to do ( or at leastused for a similarity or likeness - although I know you were kidding)....LOL.... You were weren't you???
Anyways is the Sikolene the stuff in the "can"??? Ive heard really good shit about that too...Last edited by Supergenius; 06-23-2008, 03:46 PM.750 WHP/575 TQ CD5 Raping a street near you....
realHomeMadeTurbo.com / Kaizenspeed.com / LSD Motorsports / Tempest Racing /SpeedFactory /ExplicitSpeedPerformance
GFI HOLLA!!!!!!
http://www.youtube.com/watch?v=Cdiz0k0Rudw
Originally posted by Supergenius View PostRedline water wetter has decreased my temp about 15 degrees.... It works, as much as id like to SAY it doesnt, it does. IF you're going to use it, dont mix any coolant in it... Its a mis conception that the stuff raises the waters boiling point (actually alot of dumbasses think coolant does too), its not so... Its the pressure that keeps the water from boiling.
Originally posted by Losiracer2 View Postso just use distilled water and this redline stuff?750 WHP/575 TQ CD5 Raping a street near you....
GFI HOLLA!!!!!!
Actually, antifreeze DOES raise the boiling point by about 12*, the increase in pressure also helps raise the boiling point. Look it up.Originally posted by sweet91accordif aredy time i need to put something in cb7tuner. you guy need to me a smart ass about and bust on my spelling,gramar and shit like that in so sorry.
Originally posted by foamypirate View PostActually, antifreeze DOES raise the boiling point by about 12*, the increase in pressure also helps raise the boiling point. Look it up.
Hmmm Im gonna have to. Plain water disapates heat better than even a 50 50 of water and anti freeze...... The pressure is whats primarily responsible.... But if im wrong im wrong.... IT happens
EDIT: I stand corrected on that.... Learn something everyday.
""respectively, "colligative agent" more accurately describes the liquid both lowering and raising freezing and boiling point.""
Bottom line is that the water wetter works better than water by itself. with Anti freeze, or 50 50 with the weter...
Just use the wetter in plauin water. I used it with antifreeze (i was lazy)... Then flushed it and used just water and wetter and saw an additional 10 degrees cooler in addition to the original 8ish i got.
FactLast edited by Supergenius; 06-23-2008, 04:00 PM.750 WHP/575 TQ CD5 Raping a street near you....
GFI HOLLA!!!!!!
but adding this stuff to coolant also works right? Or what should I do? just distilled water and this stuff?
I'm kinda afraid to use Arizona tap water b/c its heavily deposited w/ minerals.
Use distilled + the wetter... IT WILLL LOWER YOUR TEMP MORE THAN HAVING ANY COOLANT IN IT.
/Last edited by Supergenius; 06-23-2008, 07:46 PM.750 WHP/575 TQ CD5 Raping a street near you....
GFI HOLLA!!!!!!
Originally posted by Supergenius View PostUse distilled + the wetter... IT WILLL LOWER YOUR TEMP MORE THAN HAVING ANY COOLANT IN IT.
Originally posted by mj213 View PostSometimes people have responses to questions that I silently memorize their name and from that point on, IGNORE EVERYTHING THEY SAY.
I don't know if you're serious or not, customchord, but I'm thinking you aren't kidding.
Ethylene glycol has two purposes:
1. Gaurantees fluid doesn't turn into ice under harsh winter conditions.
2. Prevents coolant from reaching boiling point in extremely hot conditions.
Antifreeze/Coolant takes longer to heat up and resist freezing MUCH better than water.
I'm sorry if this is obvious to everyone, but I merely wish to discredit the aforementioned statement about using water instead of coolant.
Losiracer2 have you tried using a colder thermostat or taking the thermostat out so the coolant is flowing the minute you start the car?-1991 Honda Accord LX H22a-
Originally posted by wed3k View Posti hope you're not yelling at me because i already know all this shit. i run water wetter in my stuff. i just need a lwoer temp fan sensor.750 WHP/575 TQ CD5 Raping a street near you....
GFI HOLLA!!!!!!
