What is the difference?
Is port matching - where the head outlets are enlarged to the header port diameter, and the porting continues about halfway back into the ports?
And is porting where the ports are enlarged right up to the valves?
I have just started doing some, from what I can gather "port matching"?
Also, what (if any) results do you think I will expect to see from enlarging the ports out to the blue lines in pics below (I've already done #4 exhaust port)
Application: F22A1 with 16G turbo, Also on the look out for an H23 intake manifold to go with this head and Bisi's turbo cam.
