sorry for the delays fellas but theres quite a few hurricanes outside...still tweaking tho
** CHIPPED ECU TUNING JOURNAL **
The greenline is the air fuel ratio
Red line is lamda
Blue line is RPM
Purple line is Throttle Posistion
and the light blue line is nothing as of yet
cruising a/f ratio pic
a/f - 14.7 where the vertical white line is
rpm - 2583
throttle position - 17%
A/F at idle
a/f - 14.9 where the vertical white line is
rpm - 889
throttle position - 7%
The Air fuel ratio i ran at the track. 1st-4th gear. Notice how flat the curve is anytime i'm WOT. Also notice how long it takes for the rpm's to climb while i'm going into 2nd gear even tho i was WOT(look at the throttle position to figure out where 2nd gear is...1st gear is that squiggly ish). The waivering in the rpm lines are more examples of the clutch slipping.
a/f - 11.9 where the screen ends
rpm - 5236
throttle position - WOT...for some reason it registers in at 87%
I know those may be hard to see but i wanted to show u guys what exactly i'd accomplishedLast edited by MRX; 09-30-2004, 05:34 PM.Knowledge is power...in EVERY sense of the word
these are just bigger pix of the ones above. They have trouble loading. Try refreshing alot to see all of them
Last edited by MRX; 09-30-2004, 05:38 PM.Knowledge is power...in EVERY sense of the word
my car is now officially run by uberdata....best thing thats happened to me in months haha
I <3 MRX
FYI...i gave R33 my map to get him up and running properly. R33 come back with comments and suggestions.
and i <3 u 2 ericLast edited by MRX; 10-01-2004, 10:15 PM.Knowledge is power...in EVERY sense of the word
well i drove home tonight with it and it was perfectly fine. i was able to finally get on it a little and WOW its like driving a whole new car. so smooth. i still didnt go crazy though i still want to get a feel for the map and what the car is doing at certain points. as far as my POS autometer A/F guages reads the A/F is almost perfect...except of course when you let off the throttle and it goes into big vac numbers (25+) in which it becomes super lean. but its not a big deal, mabye ill play with the map scalers tommorow if i have time.
to MRX's tunning
Great to hear eric. Hopefully u know something i don't about modifying the vacuum readings. I tried, the thing goes screwy. I'm meeting up with carlos 2morrow and i'll have him look over the map and fine tune if possible. Between the 3 of us attacking the high vac prob we're bound to figure it out.
p.s. quit bein' a pussy a lay into it lol!...WOT all gears
be free my friend be freeKnowledge is power...in EVERY sense of the word
nice writeup....i just downlowaded uberdata. I''ve been looking into this for a while. The only thing is i drive a gsr powered hatch. The reason i'm on here all the time (reading, not posting) is that my roomate has a 93 ex and we just bought a head to p&p and do a regrind on. We're planning on tuning it with uberdata, but are there any good f22 basemaps? I figure that with I/H/E/cam/p&p we will need to add some fuel.
what about the throttle secondaries?
p.s. does anyone want to sell me some of the hardware i'll need?H.S.A.E.
90 CRX Si - gutted, caged, Bisi F2d kit, close ratio LSD trans, F22A6 - under construction
99 civic LX - y8 head and trans, lowered, blowing cold AC, and getting 35mpg.
i have a p06 that is already chipped..i have to do a few tests to make sure its in perfect working condition before i would sell it. but ill let you know
The secondaries can be covered with any rpm activated switch...a cheap shift light could operate them ya know.
Update: I've been given instructions on how to correct the lean mixture under heavy vacuum but now the programmer has stopped working again. Eric is the only person that can complete my map currently so hopefully he'll give it a try and come back with good results...or atleast different results than the lean mixture.
but since i'm getting closer to completion here is some info on chipped ecus and uberdata
Uberdata Forum - http://www.ecimulti.org/uberdata/forum/
Uberdata program Version 1.66 - http://www.ecimulti.org/uberdata/dow...ble%20Version/
Homemadeturbo.com Engine Management Section - http://www.homemadeturbo.com/forum/index.php?board=6
How to chip obd1 ecu's - http://home.mn.rr.com/keebler65/honda/uberdata.html
Ecu related site - http://www.PGMFI.org
(crap load of reading but it does a body good)
quick and dirty parts package to completely chip the ecu - http://www.moates.net/product_info.p...products_id=42
Last edited by MRX; 10-13-2004, 05:02 PM.Knowledge is power...in EVERY sense of the word
got a question for u....
when i send out my ecu for u to chip will the map that u r using at the time work the same with mines being as tho i still running my regrind cam? would u have to alter it a little to add extra fuel for that, or will in be fine?
thanks...NEED RAP BEATS.....
www.soundclick.com/akcidentaltrakz
