** CHIPPED ECU TUNING JOURNAL **
    anything new lately?
      Eh, still trying to fix this 2.5k stutter...i swear its the biggest pain in my ass! Other than that most all my customers seem pretty happy with their maps. I'm also waiting on uber 1.9 to get bugs worked out so i can try that out.
        uber 1.9 is woorkiing fine, so far i have been running 1.9 for past week or so. cept i haven't tryed the datalogging portion of it. 2.5 k stutter is minimal. not to bad. good luk.
          do the cranking features work too? What i'm really looking for is the vac triggered open loop switch for the guys with the little turbos
            still waitin for u to fix my start up problem lol j/m its straight it feels weird now if it starts on one....is that bad?
            ~Nick~
              haven't even looked for the triggerd open. but the crank seems to make a difference but i haven't figured out what value to use yet.
                got the zipfile link to uber 1.9? if so post it up
                  which one you want? 1.9 doesn't have crank features
                  1.92 is working so far but it claims to not have dataloging features working "pretty much the same as 1.7 datalog wise". haven't tryed well anyways let me find the link real quick.
                    well crank features don't work when you save your files. so im deleating this link.
                      haven't had the chance to get 1.92 going but thanks to an unknowing Iamanoymous the stutter is solved. I was about to send out an ecu to acclipseh23. He has an f22b like todd and i was testing the map for it to see if everything was ok and if it was ok to send off. Well sure enough the stutter spot was gone. Weird thing was that i'd originally copied the h23 timing that Todd was using and the stutter was still there. So i go back and copy and paste the entire h23 timing map to my map...and the stutter was there. Fine, so then i copy my map onto the h23 map and leave the timing...stutter gone Don't ask cause i don't know lol i'm just glad its gone. I need to retune the a/f's but the manifold leaks so bad i'd get false readings so i'll have to wait awhile to do that.
                        My UD 1.66 has no stutter problems... and starts on first crank
                        Shift_BOOST
                        BOOM!
                          Yea, yours started up as if you thought about it starting up and so it did. On the other hand, mine still has the start problem. As a matter of fact it pretty much never starts on first try. Maybe when you get back into town you, MRX, and I can compare and figure it all out.
                          "This is a jaded bunch. To gain notice, you have to challenge conventional wisdom, test assumptions, and ignore the naysayers."
                          FS Part out thread koni/skunk2 suspension, jdm pole, HID retrofit, Tanabe exhaust
                            http://uberdata.pgmfi.org/forum/atta...erdata1.93.zip
                            1.93, it has supposeably some of the new fuel modifiers working. i haven't played with it yet just the newest version out.
                            1.93 will not datalog. to datalog u must use 1.7.
                            MRX, so tods timing map will work on are f22 correctly? or will the timing need to be adjusted slightly to fit the f22 setup?
                              but...its like...it wasn't the timing, it was something in the code. I took his entire timing map and pasted it over my map. The stutter only went away when i put my fuel map on his map. I changed over all of my timing from 6in/hg through boost and modified the vac timing so its powerful on daily take offs. I'll post it up soon, but so far its great. That stutter made the car a pain to drive if i wasn't boosting, now its enjoyable again.
                                can't wait for u to post it! i guess it must be somtihing to do with ubers bugs that are not all fixed. i had crazy things happen with uber somtimes so i wouldn't doubt that it did soming crazy to to the formating of the old map.
