Originally posted by midnite racer x
** CHIPPED ECU TUNING JOURNAL **
update: Grumpy and I met up last night and after some failed attempts at getting him onto uber 1.7 for some reason we gave up and i just copied and pasted my current map to 1.66. Started her up and it feels ALOT smoother than the last map. I'll await his notes on whats good/bad. We're shooting for next week to do work on his car. So the n/a f22a map is getting closer and closer to completion.Knowledge is power...in EVERY sense of the word
oh my gosh this map jus might be the one i haven't found ne dead spots still have to crank twice to start but no biggy and lets see oh idle still low with the turn of a screw but not as low as it use to be i am very excited can't wait to dyno it then we will have it all the problems worked out.~Nick~
hey mxr good write up man almost done reading it all.....started a couple of hours ago with a couple of distractions..right now i purchased a p14 ecu and am going to be swapping in the f22b shortly and boosting it near the end of summer. by august-ish do you think you'd have a map setup for a uberdata-chipped p06? im most likely goin with the dsm setup, still contemplating turbo and manifold but im really interested in your work and i have zero chipping/tuning knowledge/expierance so im looking up to you. thanks again
Originally posted by CB7DOHChey mxr good write up man almost done reading it all.....started a couple of hours ago with a couple of distractions..right now i purchased a p14 ecu and am going to be swapping in the f22b shortly and boosting it near the end of summer. by august-ish do you think you'd have a map setup for a uberdata-chipped p06? im most likely goin with the dsm setup, still contemplating turbo and manifold but im really interested in your work and i have zero chipping/tuning knowledge/expierance so im looking up to you. thanks again
http://www.cb7tuner.com/vbb/showthre...light=wideband
we have a map for it alreadyKnowledge is power...in EVERY sense of the word
best thing you can do is learn all this b4 you ever even begin to try it. Best of luck and remember the more u know about what ur getting into the easier everything will go, things will still go wrong no matter what but you'll have the knowledge to overcome any obstaclesKnowledge is power...in EVERY sense of the word
lol did u get that out of a card??~Nick~
Somebody contacted me saying they wanted to see my latest map and compare it to what they had. Whoever it was said they'd managed to fix the start up problem also...if your reading this...CONTACT ME I LOST THE EMAIL/PM/WHATEVER LOL!!! Its like the final bug, and its so friggin aggravatingKnowledge is power...in EVERY sense of the word
so that means no more to crank starts??~Nick~
hey mrx i ran into another problem recently everynow and then when i go to start my car that normally takes to cranks it won't even turn like i wll turn the key and it will jus go click and ill have to sit till the check engine light goes out then turn and it usually still takes two cranks when do u think me and u can get together agn?? i am still waiting on that dyno let me know peace~Nick~
sounds good~Nick~
a lil update haven't ran into that problem with turn the key an no crank i am guessin that the fuel pump was clogged or it could have been what ever u did at sonics lmao on a rainy day but ya i am excited to dyno nxt friday hope results r good more on uberdata then on the piece of paper lmao~Nick~
