how big of an inverter?
    how big of a wattage inverter would you need to power a 7 inch lcd and a dvd player at the same time?
    would a 400 watt inverter be big enough?
    Get a FREE PLAYSTATION 3 before anyone else can!!!
    Sign up HERE!
    400 is plenty. The lcd onyl draws the slightest amount. The back of the dvd player should have a sticker stating how much power it consumes. Is your lcd run on AC power??? Most are DC, so you just hard wire off a fuse or something. I have a 350 watt inverter and the dvd player and ps2 run at the same time no problems. In case your wondering, i have the dvd player to play dvd-r's and all other types of media that the ps2 cant read.
    A wise man never plays leapfrog with a unicorn.
    Frost White CB7 Crew - Member #4
    Official Ebay Whore Crew #9
      awesome...well most of the screens ive seen have been both ac and dc so i figured if im gonna hard wire an inverter i might as well plug the lcd into it instead of having to hardwire that too
      Sign up HERE!
        That's cool if your screen comes with the 2-prong power adapter. Sometimes you have to buy that as an accessory. I would hard-wire that screen in still though, so you have an extra outlet(s) for plugging in a camera or anything else when you need juice. It's really easy to wire in the screen, just go from a fuse, I used the power antenna fuse b/c it only gets power when the key is turned and I wont have to worry about turning it off, but, to each his own
          is the fuse you wired it to in the fuse box in the engine bay or inside the car?
          Sign up HERE!
            The one inside by yer foot there. I just looped the bare end of a wire around one of the prongs on the fuse and put it back in. I didn't change the fuse to a higher one (i think it's a 20 amp) because the screen only said it drew like 0.25 amps or something crazy low like that.
              oh, i didnt know there was a fuse box under a kick panel beside your foot, whoops
              Sign up HERE!
