What is wrong?
    What is wrong?
    Ok, I took my subs and amp out of my car to put my interior back. About two weeks later I hooked my subs and amp back in. Now they arent working, light does even turn on on the amp. Everytime I take my subs out I make sure to unplug the fuse in the wire so if the wire touches the car it does not blow it. I have hooked my old amp to the wires and still doesnt do anything. I have put new fuses in both the wire and amp. I have took the positive and negative and touched them together and nothing happens, no sparks or snapping sounds. I dont know what is wrong?
    Instagram: n_buttz
    The Jeepster ____ The CB7 ____ The TE38 ____ The S13
    Hum... Guessing that you do have power at your battery. Sounds like your problem is in your wires. Your not getting any power or your not getting a good ground. If you had a good ground and a good hot wire when you brought the two together you should have gotten a nice little spark from that short lol. Recheck your wiring would be my first suggestion.
      I do have power at my battery. I think it is in the wires also. I have checked the ground cable, even unbolted it and rebolted it in the same place. I think I need a new power cable which Im going to need for my new fuse. Also the power cable looks to have been split and reconnected at one point. What size fuse is suppose to be in your wire, isnt it a 30amp?
      Instagram: n_buttz
        Depends on what the total draw for your system is. Check the battery fuse to make sure that isn't blown (you DO have a fuse on the power cable within 12" of the battery, right?) then follow the cable run to make sure there aren't any breaks or shorts.
        ~If everybody you knew jumped off a bridge...the bodies would pile high enough to break your fall if you jumped after them.~
        Project Deerslayer
        UPDATE: DEER - 2, CB7 - 0
        '93 EX 5-speed coupe
        Short ram intake
        Tenrai Himoto catback
        Smashed front end
          where in the car did u bolt the ground?
            Is the remote wire hooked up? That'd make it not turn on..
            well, nm thats probly not it but where does your amp wire go? Probly the ground.
              x2^^
              Originally posted by Juice21
              thnx pimpette, your car inspired me to go lower
              Originally posted by GameChewer
              Shiit i heard that, you heard the queen!
                The fuse isnt blown and the fuse is within 12" of the battery. I will check for breaks or shorts later today.
                It is behind the seat, the car came with the wires alreay in it.
                Im going to check that later today, pull the deck out and see if the wire is undone.
                Instagram: n_buttz
                  check to see if your getting power from the power wire with one of those little uh i forget what there called the things with the light inside that looks like a screwdriver lol.. but if you get power from that then well your getting power and find a new spot for your ground to see if you can get that to go to. i put my ground on on of the bolts for the rear speaker and that worked for me.. idk just trying to help good luck
                  My s13 Ride Thread>>><<<My Rx7 Ride Thread "What is power without control?"
                  New people click here
                    Continuity tester.
                    Project Deerslayer
                    Short ram intake
                    Smashed front end
                      Continuity tester.
                      thank you lol
                        yO! you say the power wire was cut than reconnected? check to see if they just twisted them and tapped or actually soldered the two back together. (esp if over 8 guage)
                        if your remote wire is disconnnected you would still have a live power cable (pending blown fuse or short)
                        first spot i would check is where they ran through the firewall (typically people use the fog light harness plug spot.)
                        and cam ova here is the most knowledgable and well spoken audio inclined cb7 member on here IMO
