wagons 5th speaker
    wagons 5th speaker
    does any one have a diagram showing what colored wires go to the wagons rear 5th speaker? cuz I was gunna replace it when I found out that theres 2 plugs that both seam to be for speakers?
    93 Accord LX Sedan (sold)
    Felipe, calling Felipe .. front & center .. STAT!
    A Hui Hou !!!
    Tomi
    My CB9/Wagon Thread Start to Finish:
    http://www.cb7tuner.com/vbb/showthre...ighlight=wagon
      there is 2 plugs on the rear 6x9 5th speaker. its a dual voice coil speaker.
      i removed the stock 6x9 and put a regular fuzion 6x9 in its place. you can run 1 speaker off each plug.
      DooDoo
        ^^^ so your just using one of those plugs?
          does the wagon have a stock power antenna or after market cuzz one plug is for the power antenna and the other one is for the speaker but dont know the color
            gus just call me or stop by man. get 2 6x9 and we'll hook both of them up for ya. we can do it friday evening. take a look at my crappy pic and you'll get the idea
              so is true what they say? that you need a dual voice coil speaker
              (sence your the wagon expert)
                the 2 wires u have plugged into yourstock speaker are the right and left rear channel wires. they are pretty much tapped into the wires that are ran to the speakers on the roof. so we'll take the stock speaker off, burn it, then we'l cut one of the wires and add about 3' of speaker wire so we can hook a speaker on the other side. we'll cut a nice oval shaped hole on the rear door thats on the passnger side. and vuala u have a sick set up
                  Where and how much do you charge to put the dual 6x9s in???
                  and my roof speakers dont work???
                  is there plugs up there??? i havent checked yet.
                  DooDoo
