Capacitor n00b, help
    Yeah I need a capaitor, my lights dim when the sub hits
    MTX RoadThunder RT2100X
    Sony Xplod 12"
    I have no idea where to start
    wat?
    You can get a cap and it will help a bit. But honestly I would just invest in a High-output alt and a yellow top battery.
    The Wood grippin' - Mesh spinnin' Accord
    My Ride | Cars from my trip to Japan | Japan II
      I have a new 850CCA battery so im keeping it for a while
      wat?
        Well then a HO alt is a good choice.
          how much do those run?
          wat?
            Well you can get stock ones rebuilt to High standards and I was told around 150+ depending on how much you want it to output.
              do i need larger gauge wire alternator wires?
              wat?
                I dont think so.
                  try a big 3 upgrade and more grounds!!!!! better throttle response and helps with dimmin lights
                  Members Ride sold...
                    upgrade the big 3 like it was said!...IMO caps are useless. unless you upgrade the rest.
                    Retro!
                    Hater
                      what is "the big 3"?
                      wat?
                        batt-alt batt to ground. and i also ran a 4ga to the main fuse box under the hood! if sumone has the codes to post pics i have a pic of my wires under the hood to upgrade!
                          Well when I had my system I had a capacitor and a stock alternator and a interstate battery and I had very little dimming of my headlights. I had a 1 farad rocksford fosgate capacitor. Hope everything works out
                          Maple50175 - you're annoying =P
                          Brandoncb7 - I don't mean to come across like an ass but I see why you irritate Aaron now.
                          JoshM - Crotch rocket = chick magnet.
                            get a good battery deep cycle and prefered gelcells. im pullin 2700rms on 2 batterys and i have a little bit of dimming. that amp doesnt even put out 500 watts. get u a red top battery and ull be set. a friend of mine has neon a 1000 watt rms amp plus everything else and has no dimming issues.
                              i get no dimming i run 2 rockford amps with 4awg wire 1 farad stinger cap and cant wait to get my yellow top back in but no dimming issues since i got my cap so good luck
