This is for the cars equipped with an auto tranny but can also be used with a manual one.
X88 - AC Connector
31 - Battery -
30 - Battery +
T1 - Coil
M12 - Fuel Pump
X1 - Diagnostics Plug
B147 - TPS
Y3 - Injector
R41 - Injector Serial Resistor
A5 - Gauche Cluster
Y104 - EACV
Y99 - Idle Air Control
B54 - Crank Positioning Sensor
Y28 - Exhaust Gas Recirculation Valve
A35 - ECU
B75 - Rpm Sensor
B132 - Cam Positioning Sensor
15 - Ignition Switch ON
50 - Ignition Switch START
A52 - Ignition Coil Power Output
B149 - Exhaust Gas Recirculation Sensor
K46 - Relais Module
S249 - Switch Auto Stick
S231 - Switch Power Steering
B83 - MAP Sensor
Y102 - Intake Manifold Tuning Valve
B25 - Intake Air Temperature Sensor
B24 - Coolant Temperature Sensor
A57 - TCU
A166 - Distributor
B72 - O2 Sensor
H63 - Warning Indicator Engine Management
B33 - Speed Sensor
G1 - Alternator
F - Fuse
X88 - AC Connector
31 - Battery -
30 - Battery +
T1 - Coil
M12 - Fuel Pump
B147 - TPS
Y3 - Injector
A5 - Gauche Cluster
Y104 - EACV
A35 - ECU
B75 - Rpm Sensor
K46 - Relais Module
B83 - MAP Sensor
A57 - TCU
A166 - Distributor
B72 - O2 Sensor
B33 - Speed Sensor
G1 - Alternator
F - Fuse
