Remote Start Help
    Remote Start Help
    Any One Know How Hard It Is To Do Any Tips Or A DIY On It ?
    if youve done and alarm before its not too much more work
    12 VOLT CONSTANT WHITE (+) IGNITION SWITCH
    STARTER BLACK/WHITE (+) IGNITION SWITCH
    IGNITION 1 BLACK/YELLOW (+) IGNITION SWITCH
    IGNITION 2 WHITE/BLACK (+) IGNITION SWITCH
    ACCESSORY YELLOW (+) IGNITION SWITCH
    PARKING LIGHTS RED/BLACK (+) FUSEBOX IN DRIVERS KICK PANEL
    POWER LOCK BLACK/WHITE (-) LOW IN DRIVERS KICK PANEL
    POWER UNLOCK BLACK/RED (-) LOW IN DRIVERS KICK PANEL
    DOOR TRIGGER BLACK/WHITE (-) BROWN PLUG LEFT of STEERING COLUMN
    TRUNK PIN GREEN/BLACK (-) GREEN PLUG LEFT OF STEERING
    HORN LIGHT GREEN/BLUE (-) STEERING COLUMN HARNESS
    TACH BLUE @ DISTRIBUTOR
    BRAKE GREEN/WHITE (+) SWITCH ABOVE BRAKE PEDAL
    FA1
    355
      if your trying to do this yourself better get it installed professionally. our accords arent hard to do but thats the installer talk, if you dont know what your doingo or wondering what is what then i honestly dont think you should try. no offense.
      Retro!
      Hater
