Ok I know the generals to hooking up a audio system, but my ?ion is can you run the remote to the antenna rather then to the headunit since the antenna turns off when the key is turned off?
Remote wire
well i no ur suppose to hook it up to the blue on the radio but i wanted to try something different. I hooked it up to the blue/white on the antenna harness thinking it was the same wire on the radio (blue) so it would do the same thing. But like i said when i did that i noticed when the key was out the amp was still on. I knew something was up then. So that must be a 12v constant then i guess.
