I was reading that 6x9 speakers arnt that great.Can someone verify this or is there mixed feelings about it?I will either be using Pioneer 6x9 5 wasy's or Pioneer 6.5 4 way's.Thanks
Speakers? 6x9 or 6.5
Originally posted by minoreparationsdon't believe everything you read. it really depends on what you like. some people like sound quality, some like bass. it's all up to the person with the remote in their hand.Members Ride sold...
The shape of a 6x9 actually does create weaker spots in the cone, which can cause distortion. Were as a perfect circle will be uniform throughout and have the same control across its intire surface. Not that it is a huge deal, but when you get down to it this is an advantage that a 6.5 has over the 6x9. But then again the 6x9 has more surface area and will push a slight bit more air (not a sub) for more midbass. Just my 0.02
Originally posted by cegpcolaThe shape of a 6x9 actually does create weaker spots in the cone, which can cause distortion. Were as a perfect circle will be uniform throughout and have the same control across its intire surface. Not that it is a huge deal, but when you get down to it this is an advantage that a 6.5 has over the 6x9. But then again the 6x9 has more surface area and will push a slight bit more air (not a sub) for more midbass. Just my 0.02FA1
355
Do it right and go with the components! I've got infinity perfect kappa components all the way around with 2 diamond subwoofers and I get compliments every time I have a guest ride in my car. Just make sure your setup is what you want. I had to buy an amp for my speakers (planned on it anyway) because all of my speakers are 2 Ohm.Been a long time. Still alive...
normal person:
6x9 on a nice stereo (has enough standard bass, nothing too much but good enough)
stereo dudes:
6.5 components ran with an amp and a nice stereo with a sub (not much bass out of 6.5 but thats why the sub is there and an amp to run that 6.5What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Originally posted by HondaB18Depends on your setup, they both have their pros and cons.Last edited by loud92CB7; 04-16-2007, 12:46 PM.Members Ride sold...
