alarm horn
    alarm horn
    is there anyway for me to jus change the chiping horn on my alarm?
    Cali.Dumps.Harder.
    well we arent magic what kind or alarm is it? and are you asking if you can get a new siren or how to change the chirping sound?
    FA1
    355
      u want it to sound differnt, or be a louder chirp?
      Retro!
      Hater
        If You Wanna Change The Siren For A New One You Can Just Cut The Old One And Wire A New One. For A Unique Sound, I Know Some Dei Sirens Have Some Lil Bittons In Them Or Sumpin And You Can Move Them For A Diff Sound
          basicly a louder one and mayb a different sound do you kno where i can get any from cheap?
          Cali.Dumps.Harder.
            It depends on the alarm, most models use a siren and NOT a speaker. You should be able to order just a siren from any mobile shop or possibly an online store. The speakers (like on my Clifford IG7000) cannot be changed out with a siren.....
            Speaker - Alarm determines output, multiple sounds, different volumes
            Siren - One sound/pattern triggered by voltage, either on or off
            1992 Accord LX - SOLD
              i think mine is a siren.
              Cali.Dumps.Harder.
                if you want to make it louder you can wire it up your factory horn ? thats what i want to do but i dunno if anyone else has done it ?? anyone know how to wire up the siren to the horn so they both and go off when alarm is set off
                ________
                Paxil settlement
                CLICK ON SIG FOR MEMBERS RIDE
                "2SIIC"
                Authentic Jerseys for sale
                http://www.cb7tuner.com/vbb/showthread.php?t=188314
                  relay conv. pos siren output to neg.. Wire to horn input
                    THE HORN WILL JUS GO BEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEP NOT BEEEP BEEEP BEEEP.
                    UNLESS YOU KNOW MORE ABOUT IT THEN I KNOW THERES A WAY TO DO IT I JUS DONT KNOW HOW
                      i don want it to be the horn i want it to beep not honk..
                      Cali.Dumps.Harder.
                        you will need a 2 prong flasher and a 4 pin relay
                        85 on the relay goes to ground -
                        86 on the relay goes to siren output (+) from your alarm (diode on this wire)
                        30 goes to battery 12v +
                        87 goes to one terminal on the flasher
                        other terminal of the flasher will go to your horn wire (+)
                        make sure you hook up a diode on the wire that goes to pin 86 or when you honk your horn it will also honk the siren, unless that doesnt bother you then just hook it w/o the diode. If you do decide to use the diode make sure you hook it up right because they are directional if you hook it up backwards then nothing will work. try it and it nothing happens then just flip it around. I think thats everything
                          sounds like everything^
                            funny...is the horn trigger a negitive? therefore it wont work that way?
                            basically instead you would have to have
                            id do it this way, its converting the positive from the siren to a negitive and going through the flasher relay.
                            first grab the positive from the siren wire and run it to the flasher relay, then the output of the flasher relay into the relay pin 86
                            30+85 go to ground
                            87 is negitive out to your horn wire under the dash.
                            this enables the siren positive wire to flow through the flasher relay, after it goes through that it is a pulsed output, then it goes into the relay that creats a positive input into a negitive output....
                            Retro!
                            Hater
                              30+85 go to ground
                              I understand how you are saying and I would think it would be better that way but not for nothin but I dont think it will work that way because if you run the flasher to the relay like you are saying it wont flash because its not getting a ground. The way that flasher is intended to work is it grounds itself through the bulb. So I figure my way it would ground itself through the horn
