Only static from speakers
    This is happening on my moms accord (97), but sure all audio is the same.
    One day, the radio just started playing static. It has somewhat of a beat to it, but nothing you can make out. Sometimes it will randomly kick back in when you turn one direction, turn on something, but wont consistantly do it to just one thing. (like it'll turn on when you hit the brakes once, but wont to it again). Anyone have any ideas? Im gonna check the ground if i can find it, and maybe the connection to the antenna although that'll be fun finding where it is (built into rear window). I have tried beating the crap out of the dashboard, and it will change the static noise a little bit, but nothing promising.
    Its also a stock headunit. Nothing has been changed/modified since it started happening.
    Sounds like the antenna has a loose connection to the hu. Have you tried any other sources of audio (cds, tapes, 8track )
    YouTube Clicky!!
      she said they do sometimes, but havent the past few times.
        what dose this mean
        In Need of an engine, just a basic f22a...pm me if you have one willing to part with.
          hey brandon i will ask my boss tomorrow what he thinks the problem could be. if nothing else he will give you some steps to diagnose the issue..
            Originally posted by kapone
            what dose this mean
            the cassette player did work a little more than the radio, but now if the radio gives static, putting in a cassette will give you the same static.
            thanks a mucho
              well i didnt get very far with your radio solution.. basically he said without it in front of him couldnt get too much. but he believes it is something wrong with the radio internally..
              sorry couldnt help more man. next time i pull a stock CD deck ill snag it for ya with the security code..
                that happened to my system. it turns out that it grounded itself out ( one of the wires, i dont remember if it was positive or negative, detached from my driver side door speaker and all i could hear was distortion and static) you never know that might be the problem
                  was it just from that one side?? because i kinda have the same problem but only from one side
                  Click ^^^ for MR Thread
                  Originally posted by steelbluesleepR
                  by the way, arguing on the net is like womens basketball, even if you win, no one cares.
                    usually a grounding out speaker will cause no sound rather than static, id guess bad deck.
                    FA1
                    355
                      It was the head unit. She got another one, and now it works great.
                        i have almost the same probly very bad radio reseptionim not sure whyi tryied figuring out everything checkall wires and they all look goodbut one thing i have along extrention to my antenna adapter
                        so it basicly a long extended antenna adapter
                        (\__/)
                        (O.o )
                        (> < ) This is Bunny. Copy Bunny into your signature to help him on his way to world domination!
                          try to play a tape/cd, and if it still is staticky then its prolly the HU. If not, then its something with the antenna.
