I was wondering if anyone has done a shift light before instead of buying a tach with the shift light?
Has anyone done a DIY shift light?
Looking for THIS?
http://www.cb7tuner.com/vbb/showthre...ht=shift+light
Try searching better. Same one 93accordcoupe93 mentioned.
Try searching for Busted_Lx's threads or members ride page ... I've seen him do it and put it on the tach. It looks smooth ...
BustedLx's pix from this thread:
Update:
http://www.cb7tuner.com/vbb/showthre...ight=tach+wireLast edited by cyclonus_cb7; 11-12-2005, 09:00 PM.
The stock tach isn't always as accurate as an aftermarket one. Or so I've heard... Who knows if that's true
http://www.msdignition.com/rpm_7.htm
^RPM activated switch... can be used for shift lights, nitrous, etc... good stuff.
^^^ that is true sometimes, but i pulled my signal from the direct point with my aftermarket tach and it is off by such a miniscual amount that it wouldn`t matter, it is something like 25-50rpm.. anyways, i mounted my tach in the glove box and shut it, then mounted the shift light on the center console, really only used at night, but then again, that is the only time i use it anyways.. other than that i just cruise.... anyways, later, good luck... also, there is another way to hook it up...
P.S.- buy whatever light u want, like a LED or whatever, then get a AutoMeter pill box, it makes a 12v jolt go to whatever it is plugged into by RPM.. used as a standalone shiftlight... this again means that it will read from the signal and not the tach, encase u r worried about it being off by 2 much...
