4 channel Amp reccomendation's
    I am in the market for a 4 channel amp to power car speakers.
    My budget is around 100 and less and I need around 75X4 atleast. What do you guys have in mind?
    Tsunami Db4440s are roughly in that range... Otherwise Fat chance. You need to at least spend 150+ shipping to get a 4 channel amp with that kind of power IMO
      exactly. your budget is a little low for anything decent. you could always get something cheap like boss or pyramid which will claim 75 watts but really put out 1/3 of that.
      however if you dont mind getting a used amp you might score something off ebay http://cgi.ebay.com/Alpine-4-channel...QQcmdZViewItem
      FA1
      355
        U don't necessarily need a 4 channel amp to run 4 speakers. You can also go this route: get a 2 channel amp rated at about 400w rms (not 400 peak, but 400w continuous) but make sure it is of decent quality (ie: punch, alpine, mtx, etc). Also make sure it can SAFELY handle a 2 ohm stereo load. When u get ur speakers, make sure they're 8 ohm speakers, not 4 ohm. Run 2 speakers on each channel, and there u go (jus my lil .02 cents)
        Check out what used to be mine
        Click Here
          I got mine at walmart for 100 bucks 4 channel 500 watt sony explode amp.
          "form follows function."
          Louis Sullivan
            No.
              man your gonna be hard pressed to get 4 channel amp that pushes 100 + watts unless its used..I would recommend a fujitsu ten eclipse 75 w / channel amp but they run around 250 unless you get it used.
              im looking for a 125 / channel amp and they run 400 plus...so good luck in the search...
                I didnt mind if it was used. Ok if its new the budget would be 200 but used at 100. In no way am i ever going to touch pyramid or boss.
                  No.
                  rotfl...good answer...
                  anyways, try ebay with that kind of budget, otherwise, you will end up with something that you aren't happy with..
                    http://cgi.ebay.com/MA-AUDIO-M483I-8...QQcmdZViewItem
                    http://cgi.ebay.com/KICKER-KX200-4-4...QQcmdZViewItem
                    http://cgi.ebay.com/1400-Watt-4-Chan...QQcmdZViewItem
                    Last one isn't my favorite, but I have heard of relatively good results from these amps. they should hopefully at least do the 70x4 you need.
                      How is the MA Audio brand? I heard about them but I never deal with them before or know how good are their products. The lanzar is not my thing....heard they are ok but not something I would buy...to me that seems like it would play for 3 months then quit on you.
                        I myself am pretty vague about the MA Audio amp. the kicker was the main one I was going for
                          you might be able to pick up a pioneer for that price.... ill keep my eyes out for you.
                          SuddenCb7 - 1992 Honda Accord EX Coupe
