thought on more anti-theft
    i was wondering if it was possible to install a push start button but hide it somewhere and use the key column as a dud.
    so the theif would have to spend time breaking into the key column and figure out it wont work.
    OR....using the key to activate the button, just playing with ideas right now.
    but if i were to disconnect th key coulm, then how would i figure out CEL's or play my radio w/o the engine on?
    for a push button you still would need the key in the on positition for it to work cause it just jumps the starter to start the car this enables you to listen to your radio and stuff.
    a cool way to do it is make an interupt where if you want to start the car, a key goes in but wont start unless you press a button then start the car. you still turn the key and all but this way its another step to attemp to start the car.
    most fords have this in their anti thefts where you just tap the brakes and then it will start when you turn the key.
    http://www.the12volt.com/relays/page2.asp
    if you really want to bypass the key you can but i think its too much hassle to do so.
    Retro!
    Hater
      HMMMMMM, thanks for the info. i will def. consider this...i know my alarm has starter kill but they'll probably find that in 10 seconds and rip it out
        On my buddys 300zx TWIN TURBO, you had to push and hold the cruise control button while you started it. it was sweet
        92 CB7 *Sold $3300 102K Miles 4 door LX
        94 Del Sol *Baught $3300 80K Miles on chasis
        and 60K miles on b18b1 motor swap
          some people have the parking lights on then it starts the car
          or some has the seatbelt in before u start it heheh
          Retro!
          Hater
            Yep, I have a friend with an si and you have to do that.
            Midwest car club
            Current rides:
            91 accord lx (5spd)
            92 accord lx (5spd)
            93 accord lx (auto )
              I always liked the little chip thing below the steering wheel. without it the engine wouldn't start I've seen these before on other cars but not too often. the only downside with this is I always lose the damn thing and it takes me forever to find.
              always out numbered never out gunned..
                Ive got the viper alarm, but the autolock! is awsome goes on your clutch, (or brake pedal on autos) and wont let you move it so you cant drive off.
                My H22A SWAP JOURNAL
                Members Ride
                  heh, you should see how much stuff i sport
                  more security than the house...
                  but i also do have a starter kill switch setup sitting in my room.
                    hehe in my manual 300zx i have it hooked up to my ignition coil =-) no start period..not even push starts.
                    Retro!
                    Hater
                      That's all nice until someone just tows your car. There are ways to prevent that as well though.
                        The way i have mine is that you have to put your seat belt on in order to be able to start the car, a thief wont think about putting the seat belt on if he is stealing the car>
                          you know your just giving a theif more ideas on how to start the car? you just gave one away.. what if we have a guest member thats a theif... you just gave him more ideas to steal the car..
                          http://www.get-gifts-for-free.com/?ref_id=4810
                          1992 Honda Accord 4dr 5spd EX- R.I.P 8/10/05
                            my cousin had a 98 prelude and underneath the armrest between the front seats right by the latch to open it up was a tiny red button that was his starter button. he just inserted the key and turned it to on but it wouldnt start it if you turned it all the way, you had to push the button first...kick ass
                              the good ole' fuel pump kill switch, you can drive with no gas.....
                              F/S:Pioneer Premier Deh-880prs w/ ipod adapter $220
