How do u remove the back speaker panel?
    How do you remove the back panel to install new speakers on a 92 4 door accord.
    92 accord lx sedan
    Phantom Grey Crew #6
    MY ACCORD
    Are you talking about the speaker enclosures in the rear deck? If so:
    Open the trunk and remove the 3 nuts (from each speaker box) from under the deck 8mm or 10mm I think, disconnect the wiring harness, pull the entire speaker assembly up and out from inside the car. Then on the bottom side there is a few screws you remove for the speaker grille, then theres about 4 screws that hold the speaker in the enclosure.
    Hope that helped.
    Jay
    Hittin Switches - Draggin XhaustAlways Under Construction
      thanx.
      92 accord lx sedan
      MY ACCORD
        Does the whole speakerpanel come up or just the speaker covers
        92 accord lx sedan
        MY ACCORD
          the whole speaker pod comes off the deck when you remove the 3 or 4 8mm nuts. the speaker grill come off when you remove the screws under the pod. i hope that makes sense.
          1cor10:31
          - 92 LX coupe
          - 96 EX wagon (sold)
            yea sort of, do you mean the three bolts around the speaker?
            92 accord lx sedan
            MY ACCORD
              PURfect sense!!
              Timaayyy .. ^ I sooo needed to know that.. thank youuu ...
              this gets better by the hour .. amazing what else you find out when you click on
              other links you've never clicked on before or you have clicked on them...
              but .. it hasnt *clicked*? heheh .. ok .. it's gettin late here .. ahem ..
              ALICE!!! add *pods* to that there list a your's .. gonna clean that 92 CB7 out tomorra.
              A Hui Hou !!!
              Paka
                I got it
                92 accord lx sedan
                MY ACCORD
                  Ya im thinking about Re-doing my Back Deck and putting Sub and take out the speakers that came with it up infront..
                  Bump!
                    make sure it has a shallow basket
                    92 accord lx sedan
                    MY ACCORD
                      I would be concerned doing that...because you don't have a box for the sub to sit in when you put it in your rear deck, and from my research on that stuff...a great deal of your sound is dependet on the type of box you use...also in my car with my subs, that shelf has been known to rattle from time to time, so unless you're going to use a dynamat type insultation on it, you will have terrible rattling issues...granted it would be a really cool install, but there's a few other issues I'd take into consideration as well.
                        They make, or used to make, open-air / free-air subs that were designed for use in areas where no box could be used. Those could be worth looking into. But IMO a sub wouldnt look good in the rear deck, I think my glassed speaker pods came out really good, if your going for looks.
                        jay
                          jay
                          Oh yeah, I totally forgot about those...my mistake...I just never looked at them when I was doing my system research...
