i know alot of people here knows how to run a new 12 volt source for a cigarette lighter, how do i run a new wire? what wire to use..and where do i find the 12 volt source to run a new wire for my new cigarette lighter? PLEASE HELP!
help on wiring a 12 volt source(cigarette lighter)
If u want to run the cigarette lighter on a constant power, go to the main harness in the steering column and the wire is a solid white wire, and if you want to run the wire on an ignition source the wire color is black/yellow, or if u want to run it on an accessory the wire is white/black, and remember which ever wire you use, make sure you fuse it.
Originally posted by mondojackalyou can run it straight to your battery, both + and - terminals, and just put a simple switch on the power (+) side...thats what i did for my friend's LED windshield squirters..
under the column is the best FUSED! at least a 5 amp fuse or a 10 at most.
for the ground just chassis ground it.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
whats the point when you can go inside the car and not have that stuff on the battery terminal?What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
