I'm going to install my indiglos tomorrow...a lil help..
Alright for anyone that has installed them. what did u do in order to install em? is it true u gotta remove ur radio,clock,vents and all that other stuff?
There is a few threads on here about installing them, so search and you'll find all you need to know. Then if you need more help, PM me and I'll explain the whole process. And for your ?, yes you will have to remove your radio, vents, all the trim around the instrument cluster, etc. but theres no need to remove the clock in the upper dash.
Jay
Hittin Switches - Draggin XhaustAlways Under Construction
the needles can break if you are not careful, but as long as you are cautious and don't just rip the gauges apart you should be fine.
Also make sure that you don't play with the needles, such as flicking them so they go all the way up and then flicking them back down, etc.. doing this can cause your gauges to not function properly, or even not function at all.
yeah this is what you do becareful not to press down on em they are very touch case sensitive i should know. Uhhhhh when you put the guages in you should hole the needles up at an angle so you can just about slide them down at an angle if you want you come come down where im at i can do em for you ive taken my dash apart 8 times already installin mine doin extra previous nitrous wireing then takin the wires out all types of junk ill help for freee!
