today my cd player just started goin crazy and shut off and now it wont power back up....i bought a new clarion cd player and its still not powering up.i checked all the fuses and i know 100% that its wired correctly. does anyone know why its not getting power?
cd player problem??? help!!
your either missing constant, accesory or ground. best way is to get a digital mulitmeter or at least a cheap testlight ($2 from autozone for mine) and verify what you are missing. did you check all of the fuses? there is one under the hood and one down in the driver kick panel, lots of people miss one of the fuse boxes. sounds like a blown fuse to me.FA1
355
Originally posted by xtr91accordthe ground in the wiring harness that plug into the player in the rear. make sure all the wires are connected to the harness and all the rca cables are pluged in correctly
not too sure the RCA cables would have anything to do with it.
gary might be on to something. Check your constant power. check your ingnition wire. That one is the most important one.
MAKE SURE ITS THE WHITE WITH YELLOW STRIPE! NOT THE YELLOW WITH WHITE STRIPE. THATS THE SPEAKER WIRE! DONT MAKE THE SAME MISTAKE I DID!
lol
Claire - '92 Mercedes-Benz 500E - AMG&Bilstein Treatment - The Wolf in Sheep's clothing.
Alice - '97 BMW 540i6 - Dinan Tuned. - Low Profile Weekend Warrior.
Felicia - '11 Ford Fusion - Luxury Package - Daily.. daily.. ugh.
Originally posted by JoshMOkay to do: "I'm sorry I broke your mailbox, here's $100.
NOT okay to do: "I'm sorry I fucked your sister, here's $100.
power to radio
Just to make sure that you are wiring up correctly take your radio and run a hot line to the battery(fuse on the wire if possible), ground out to the car or the frame. If the pos and neg run directly to the battery your radio should turn on. Just be careful not to short out on anything.
