i want to make a fuel cut off switch for my accord. anti theft is for me...i want to get it from the fuel pump (yellow wire back there)but i dont like the idea of running a wire all the way to the front where im going to hide it, and then run a wire all the way back to the fuel pump. i feel unsafe
i will be using a 30amp switch rated at 12v dc with an inline fuse but someone mentioned in another forum to use a relay instead of a switch...
can any one help me wire this up? i dont want to go wrong with this install cause its my fuel pump...i want to be safe.
maybe there is another spot, either than the fuel pump relay, that i can tap into the fuel pump?
please help me out. thanks!
