fuel pump...making a relay/switch
    i want to make a fuel cut off switch for my accord. anti theft is for me...i want to get it from the fuel pump (yellow wire back there)but i dont like the idea of running a wire all the way to the front where im going to hide it, and then run a wire all the way back to the fuel pump. i feel unsafe
    i will be using a 30amp switch rated at 12v dc with an inline fuse but someone mentioned in another forum to use a relay instead of a switch...
    can any one help me wire this up? i dont want to go wrong with this install cause its my fuel pump...i want to be safe.
    maybe there is another spot, either than the fuel pump relay, that i can tap into the fuel pump?
    please help me out. thanks!
    Retro!
    Hater
    some other foos car
    source... http://www.1300cc.com/howto/how2/rewire.htm
    Retro!
    Hater
      http://www.civicland.com/diy/misc/fu...ffswitch.shtml
      thats a switch type...looks pretty basic...is it safe? iono
      i like this idea better, less complicated and looks safe, i just dont want my car to die on the road! haha
      Retro!
      Hater
        You already HAVE a relay set up to do that. It's the MAIN RELAY. All you need to do is disrupt the trigger power to the relay. Then it'll act like the main relay is bad.
        Visit us at http://www.valleyspecialists.com for all of your Honda and Acura service needs!
          really, would you happen to know which pin is that??
          but wont robbers see that under there....or id have to be really creative, is there anything wrong with the way im setting it up? thank you man!
          so switch on the relay...?
          relay is hella complicated if u ask me....haha
          Retro!
          Hater
