System
    System
    I just finishing installin mine.. but i have one small problem.. there wasa black cap on the passenger floorboard.. i pushed it out and ran my 10 guage power wire.. the wire is pretty thick anyways... i was wondering what can i use to cover the hole up.. or even the sharp edge.. help me out.. i lost the stock plug.. so hmm? if i was to use grommets i would have to pull the wire back out.. take off fuse and whatnot and blah blah.. and i don;t want to do all that since it took me 1hr to get the wire up towards the hood because there was things in the way and whatnot.. or does anyone know where i can get a grommets thats like snaps open so i can slide it over the wire..
    my last resort is taping up the wire so it fits and cover the hole.. let me know guys..
    some people i heard used nothing.. some said they wrapped the wire with a sock.. let me know guys..
    http://www.get-gifts-for-free.com/?ref_id=4810
    1992 Honda Accord 4dr 5spd EX- R.I.P 8/10/05
    Originally posted by SteveB
    Slit the grommet.
    split??
      no slit, cut the grommet with a blade from the center to the outside not in half. that way itll go around the wire. if you want grap some strip caulking from home depot to fit in any gaps.
      FA1
      355
        i got it i just put wire loom on it.. tape it up till it was flushed mounted with the hole.. should do till i upgrade systemm
