so im wondering about mounting 80+ pounds of crap in my trunk (amp is mounted on sub box, its heavy) I would bolt to the wooder thing, but would that hold so much weight? do i need to go down the the metal in the truck? how did you peeps do it?
subwoofer box mounting in trunk.. WHERE? HOW?
if the amp is mounted to the sub box as u said then don't mount the sub box anywhere. it shouldn;t move at all. just shove it in the rear of the trunk inbetween the strut towers. i have 2 sub boxes and i drive like a mad man and they don;t move all too much maybe an inch here and there on extreme turns.
Sorry to revive an old thread, but i prefer to use the search button instead of creating more and more threads
Like OP said, how would i mount my sub?
Its a 10" with the amp bolted onto the box.
Unlike what some others have said, my sub likes to change its place ever so often and disconnect itself.
This mainly happens when taking sharp turns and stuff haha
So yeah, can i just bolt it to the thing underneath the carpet???
Thanks again guys┌∩┐(◣_◢)┌∩┐
ghetto way- bungie cords
better way- L bracketsBlake.
1994 Accord Part out!
Me and my step dad's 1991 Accord EX Coupe MRT
82 accord-rip, 94 geo-sold, 82 cavilier-rip,81 civic-rip,88 accord- rip, 88 legend- rip, 91 civic- sold,97 geo-sold, 92 accord- sold 94 accord- RIP, 1990 Camry- RIP
Originally posted by rave93 View Postso from the box to that piece under the carpet?Blake.
Or, get a piece of plywood or MDF, screw your enclosure to that, then put the subwoofer in the enclosure.
I cut the board to fit between the trunk rails, screwed the boxes to that and installed my subs. They won't come out of the trunk unless you unscrew everything, and they haven't moved since I finished the job.
A very slick way to do it, to keep the box from sliding around is industrial velcro. Put the stiff side on the bottom of the box, and then place it where you want. It will grab onto the carpet and keep from sliding around...
Been There, Done That. No brackets/screws/bungee cords/rope/ or anything else visible...
Disregard females, acquire currency.
My 2003 Nissan Maxima Members Ride Thread
DIY: HOW TO POST PIC(S)
Custom Lowz idea sounds like a very good one. I screwed small rubber feet to the bottom of my box. They are super easy to find and most hardware stores sell them. The box really didn't move at all on the carpet but I screwed two L brackets into the semi-hard material that lines the sides of the trunk just so it would not budge. In my area I believe it is a law that you have to have your system bolted down because somehow somebody got hit in the head with their speaker box and killed (I have no idea how you could place it so this would happen) and that was my other reasoning for the L brackets. I have never heard of anyone ever getting a ticket since it is obviously not visible and most people probably wouldn't care but I just thought I would throw that in Hope this helps.
