Help with Aftermarket Horn wiring.
    U see the clock spring on right. Has 3 pins, horn has 2 pins to place the wire. I never hooked up a aftermarket horn b4, any help would b great.
    The right looks like 2 pins to me
    C-3PO's MRT USDM yo!
      right 2, clock spring 3.
        So splice the blue/red red on the clock spring or the main wires inside the plastic shroud.
          I see a blue/red on the clock spring. I'm gonna say that's what u r talking about.
            I want to test the horn switch b4 I install it. I have a rechargable jumper cable and a hub with a alarm siren. I want to b able to push the horn and the siren goes off. How would I start?
              For rite now imma have to stop. The connector for the clock spring the end part.. I don't no where it gos. I took off my old 93 srs wheel off and the clock spring. Used a clock spring from a 9091. Anyways there's no place to connect it to.
                So you're trying to wire the siren to go off with the horns? Or are you trying to wire in a horn for an aftermarket wheel? I'm kinda confused.
                  I wanted to test the horn switch with the siren.. push the horn switch in. Siren goes off, tellin me the horn works.
