Cluster light illumination not working...
    Okay so here's my minor problem...
    When I turn my lights on, the dash lights up and everything. The numbers on the speedo lights up, however the white light that shines towards the face of the speedo does not light up on the left side. I have pictures to show. On top of that, I want to know what I have to do to fix it, new bulbs? New cluster? Or maybe a fuse? Either of the three is doable, just let me know which is easier? More cost effective? Or maybe a different alternative?
    This isn't a big issue, however I have a disorder that small little things like this bother the crap out of me.
    I did not edit the files, so they are BIG. However, just click the links and it should work fine!
    http://i.imgur.com/MYLa0Nc.jpg
    http://i.imgur.com/Vs84omB.jpg
    First picture you can CLEARLY see what I am talking about.
    Second picture, is POV from under the right side of steering wheel looking up. Seems like the open clear cover to where the lights are.
    @ Mods, I honestly don't know if this is the correct spot to put this. So feel free to move where necessary.
    Not sure why you're making such a big deal about this lol. You have a burnt out bulb. Just replace it. its a 74.
    wat?
      Thanks.
      Is the bezel the only thing I need to remove in order to get to it?
        You will also have to remove the fasteners that hold the cluster in, then you can tip it forward and service the top. You may have to unplug a harness or two to tilt it out forward, but nothing hard.
