So I upgraded my deck and noticed that the sound volume is diffrent from the right being quiet and the left being louder. it used to have a cutting in and out over bumpy roads problem that i fixed but now its just a bit quieter than the left. I noticed that there are 4 wires on the left and 2 on the right could this be my problem if i'm missing wires?
rear speaker sound balance problem
Okay on the rear there are 4 wires each. I think the last owner must have cut 2 of the 4, the speakers are the same brand and it took switching wires a cupple times but I think I fixed it... I will keep you updated
Originally posted by evil_demon_01Do it once, do it right.
Saving a dollar is not worth risking a life.
White -91 LX Sedan - leather converted
Mulberry 91 EX Sedan
The project 92
in some decks, having your negative and positive speaker wires reversed can cause this. make sure the settings on your deck are correct - the fader is set to 0 or centered for rear/front and left/right.
this may or may not help you, one problem I've had with rear speakers in my cb is with aftermarket speakers when the pins that you connect the wire to are close to the chassis of the car, they might touch, even when secured tightly and cause it to ground off. make sure everything is wired properly.
and as mentioned earlier, you should only have two wires going to each speaker unless there is a crossover installed. and even then, you should have the same amount of wires on each side.Everyday is one day closer to completing my cb7 <3
