Originally posted by cloudasc
View Post
Running two amps
Originally posted by kapone View Postground wires especially a poor engine ground wire causes head light dimming... upgrade the grounds in your engine compartment and watch that problem go away...
Originally posted by kapone View PostThis is my problem with forums...
Theirs a lot of advice being given with out any real info from the original poster... so basically its all useless...
First. what make and model of amps is the op using...?
Telling us it has 150 watts, is like me stating i drive a 140hp car... can I win a race with it...?
its a pointless question with out details...
Second. what size wire can you fit in this amps...?
My alpine 4 channel can fit a max 8 gauge input, but my phoenix gold 4 channel can fit a 4 gauge ...
again knowing this would help in the advice given.
Anyhow for running your rca's my guess is your deck has a RCA out that's specific for your subs. I would run a RCA from the deck sub output to your rear sub amp. if not then using the RCA outs on the other amp should be OK....
With the little power your amps have your lights shouldnt "dim" you might have a week battery or alt. I'd say run 4 gauge if you can if not run 8. The 2 gauge wire is probably really 4 gadge wire. You probably should go to a car audio shop and get there opinion...then do it yourself if your trying to save money there opinion dosnt cost you anything...
Duval Vector amp. It is near impossible to find info on it, one person on here found it once but in German.....
(I stated that I don't know what the amp it, my buddy is going to give it to me and he doesn't know anything about it, I still don't have it.
In the duval vector I can run 4 guage wiring.
again knowing this would help in the advice given.Originally posted by SPLCB7 View Post^^^ the op says he dosnt know what gauge wire he has (and ive never seen 2 gauge wire in a car) so there's no way he would know what gauge wire goes into the amp. A little common sense goes a long way...
The head unit is a Jensen UV10, It has one sub output. I used a connector that goes from 1 female-2 female so I can run the rca's back to the sub.
As too my lights dimming, I need to do the big 3. Going to buy some wire once I finish my rust repair and do that. Thanks for the helpLast edited by cuate01221; 02-12-2012, 08:31 AM.
Sorry my common sense stops at just simply reading the gauge on the wire....
In Need of an engine, just a basic f22a...pm me if you have one willing to part with.
Originally posted by kapone View PostYou realize I've never in the 20 years of doing this have encountered a name brand of audio power/ground wire that didn't put the gauge right on the wire it self...
Originally posted by SPLCB7 View PostOld worn wire and cheap wire dosn't list always my guess is if you have been doing car audio for 20 years you wouldn't cheap out on crappy wire noobs do. and that's a good thing but they don't know any better.....
I'm not looking to compete in competitions, just looking to have a nice system.
