Electrical Questions Help!!!
    Could an electric problem cause the following symptoms some of which resemble issues with fuel pressure and timing.
    1. Cold idle out of spec
    2. Warm idle at spec but drops to 450 every 30 seconds
    3. Frequent stalls
    4. Some Cluster lights, the CEL and the two next to it not working
    5. When I turn the key nothing happens sort of like when you got a dead battery, but the only difference is none of my lights go dim and the only things that don't work and in #4 above.
    IridiumCore
    HCK-The Beginning
    Your drunk she doesn't look that good.
    1. I think that's more of a mechanical problem, maybe IACV.
    2. Same as 1.
    3. Could be anything fuel, spark, air
    4.Definitely electrical problem here.
    5. Check your ignition harness wires, and starter relay.
    YouTube Clicky!!
      2. Same as 1.
      Thanks most appreciated.
      IridiumCore
      HCK-The Beginning
