Did my wire tuck and now cluster or windows dont work!
    Yea I put a power wire to one of the connceters on my cluster and spliced it into a power wire on the cluster and it cut. Straight on and fixed my windows
    http://www.cb7tuner.com/vbb/showthread.php?t=176523
      So that sentence is hard to comprehend...can you clarify exactly what you did?
      My Member's Ride Thread
        Sorry about that. Pretty much my cluster was not getting any power sowhere the power wire I. On my cluster which is yellow I spliced into it with another wire and with. That other wire the other side went to a power like main relay or. Somewhere in th fuse box just make sure you put a fuse to the power wire other wise it wll burn out and hook it up to a power wire where it will only cut on when you turn the ignition on
          Hope your car doesn't catch fire...
            He fused it hopefully with like a 1A or 5A fuse.
            Well I guess good job cause it works. Did you solder or crimp the connection?
            YouTube Clicky!!
              yes i put a fuse on it and soldered all the wires. I kind of still think i should just get a new harness but just dont know how hard it is to replace and to take out.
