Did my wire tuck and now cluster or windows dont work!
Originally posted by flashbycb7 View PostOk I will double chec everything I just don't know howdoing a wire tuck on my engine bay can mess up my windows and my cluster lights whn everything else works on the door and my interior lights all work alsoWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
I mean your saying no matter how hard you tell mei don't listen but all your doing going to help me don't write on the is talking shit if you are not going to try to help me don't write on his forum.. everyone else than you for your help I will double check everything you guys said to and look over my wiring diagram and the only ground I do not have cnnected is the abs because I don't use that anymore. There is also one ground wire that goes from the fusebox to the battery do you know where the other thick ground wires goes to on the fuse box?
Originally posted by flashbycb7 View PostOk cause one wire on my fuse box I didn't ground for some reason idk why one ground goes to the battery and the other one ios sopposed to be grounded correct?Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
No I did double check all my wiring because that one ground wire I had hooked up too a positive to the battery and that's why whhhen I hooked up my battery one of my wires melted so it did used to be on to another wire. So I did double chec my work that is why I know now that is a ground instead of a positive wire now
Originally posted by flashbycb7 View PostNo I did double check all my wiring because that one ground wire I had hooked up too a positive to the battery and that's why whhhen I hooked up my battery one of my wires melted so it did used to be on to another wire. So I did double chec my work that is why I know now that is a ground instead of a positive wire nowOriginally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
