ok i will tommorrow
Did my wire tuck and now cluster or windows dont work!
I had a similar problem with my wire tuck, make sure your grounds are cleaned and covered from the elements. after a few showers my cluster would go crazy and my wipers would not work.
Originally posted by Uncle WilleyWhen I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
Originally posted by flashbycb7 View PostYes I took the whole dash out but nevr messed with any of those wires and specially not anything to make my windows not work and so I unplugged everything from my dash.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
sounds like you need to double check your wiring from the fuse block. make sure all plugs are completely plug'd in and any wires that were extended have a good connection and are soldered. Also make sure everything is plugged in.MR:http://www.cb7tuner.com/vbb/showthread.php?t=150506
CHAMPCOUPE IS BACK !!!!
