silly question about terminals
    if i leave something like this attached will it leach power don't think it will but you never know.
    If theres no path to ground there will be no current flow.
    wat?
      are you saying when disconnecting a battery i can simply remove the negative?
        Exactly. If no metal of your car is touching the neg post, then your car is electrically dead.
        YouTube Clicky!!
          However, should metal touch the negative post and something metal that's part of the car, it's gonna be live. I usually pull both just to avoid any problems if I have to disconnect the battery.
