does some one know how to wire a push button starter? im just not sure where to hook up the wires..on my starter,it have 3 points the wires connect to.one would be hooked to positive battery cable,the other is this white/black wire that goes with the harness.( i think they call a spade clip?),and the last has a wire that connects from the solenoid and motor together..im just not sure where to connect the wire from the switch to the starter being able to control the starter to start..
push button start
Originally posted by stunin92_accord View Postdoes some one know how to wire a push button starter? im just not sure where to hook up the wires..on my starter,it have 3 points the wires connect to.one would be hooked to positive battery cable,the other is this white/black wire that goes with the harness.( i think they call a spade clip?),and the last has a wire that connects from the solenoid and motor together..im just not sure where to connect the wire from the switch to the starter being able to control the starter to start..Henry R
Koni/Neuspeed
1992 Accord LX R.I.P
1993 Accord EX OG since 'o3
Legend FSM
Originally posted by stunin92_accord View Post@ accrdkid,watsup bro,how long you'v been staying in the states? any chance of visiting the islands?Henry R
Koni/Neuspeed
Legend FSM
At the main ign harness
Black/white- pin 30 of relay
White - pin 87 of relay
ground - pin 85 of relay
Push button switch from white fused 12v - pin 86 of relay
My setup
http://tinypic.com/player.php?v=309648y&s=4
extra sense of security??? idk cool factor??? i did it to my m3 just for extra security when people drive my car they can never figure it out unless i tell them i have a push start and how to operate it...
Originally posted by TypeG View Postwhat i don't understand is why would you want to add another step to starting the car? you already have the key turned in the ignition and then you have to press a button. later.
I want to do it, but make it a real push start button. Get rid of the ignition switch, and for the button to only function when the control is near. I've been doing research on it. I will eventually do it. Just a few wires cut and soldered. Nothing that i cant handle.lol
My setup
You could make some sort of magnetic card. Just place the card where the magnet sensor is (maybe in the dash or somewhere thats easy to access but not obvious). That way theres no visual sensor or anything and when the sensor it tripped by a card (or a fridge magnet if you loose the card), it will essentially 'unlock' the car and allow for the push start to work.
