I've been looking into a set of aftermarket gauges for quite some time now for the purpose of keeping a better eye on the vitals of my car. I have read through a lot of threads on here concerning gauges and the various different methods of installing and running them.
I start this thread hoping to answer any questions that I or anyone else has concerning anything about gauges. Eventually I want to create a detailed DIY when I do go to install my own set of gauges, so I want to know everything I can to make an informed DIY.
I'll start off with the three gauges that I plan on installing and the three that I have seen together most often in cars that aren't boosted.
OIL PRESSURE GAUGES:
The easiest method I've seen of installing one of these is with a sandwich adapter between the block and the oil filter. I know teflon tape is a must when installing one of these and that you have to lube the seals before putting it all back together. Any other tips?
QUESTIONS:
*Which hole in the firewall would be the best to use for running the sensor wires back into the cabin? The hole by the ECU.
WATER TEMPERATURE GAUGES:
I have read about 3 different ways to install these.
1) a water hose adapter.
2) tapping a block drain plug.
3) a T fitting allowing the use of both the stock and aftermarket sensors in the stock sensor hole.
(could not find a picture)
QUESTIONS:
*When using a water hose adapter, which hose would be the proper one to have the adapter on? The top radiator hose.
*If you tap the drain plug, would the fitting get in the way of an oil sandwich adapter? Will the temperatures there be within what the gauge can read?
*What does this T fitting look like and where would it be (I'm a picture person; I learn visually)?
*Which method would/do you use?
VOLTAGE GAUGES:
I know this one might seem easy, but I've heard a couple of different mounting points from the battery itself to the alternator.
QUESTIONS:
*Where would be the best place to run the gauge to receive the most accurate voltage readings? At the battery.
GAUGE POWER:
For powering the gauge itself and controlling the lighting of the face. I already know that you want to find a power source that is live when the key is turned to the accessory/running notch. From what Ive read a good place to get power is from fuse panel inside the car by the dead pedal like so:
I've also read that its a good idea to fuse the power lines.
QUESTIONS:
*Where is the best place to get power for the gauges? From the battery using a relay.
*Can you run 3 gauges from this one power source or would you need to get separate power sources for each one? If separate power for each is needed, where?
*When adding a fuse, what's the best method to add one? What rating should the fuse be? Can you use one fuse for the 3 or do they each need a separate fuse?
*For the gauge lighting, where should you wire the signal wire so that when the parking lights/dash lights are on, the gauges will be lit? Can all 3 be run from this one place? The radio illumination wire will work.
This pretty much covers what I want to know for now. Whenever a question is added or answered, I'll update the first post. Thanks in advance to all contributors for your help.
QUESTIONS:
QUESTIONS:
VOLTAGE GAUGES:
QUESTIONS:
GAUGE POWER:
QUESTIONS:
