Question on the gray H2/5: - output during activation.
It says Connect this wire to optional relay (P/N 610T) to bypass sensors which may trigger the security system during operation. This wire continues to output - ground for 5 seconds after the window motors have stopped.
I think wire deactivates any sensors like shock, motion, ect... in case when the system is armed and you want to roll the windows up or down to avoid full trigger.
Question here is which wire do I connect this to? I know it's an optional relay, but how is the relay wired? Where does the relay connect to?
Thanks.
Thanks.
