Window question
    Window question
    Last night i was riding around and i went to put down my rear windows and there not going down for some reason but the front 2 are? is there a fuse for the 2 back windows i havent had a chance to look yet since it was so dark last night
    WHITEONWHITE
    Bad motor, or switch.
    YouTube Clicky!!
      Its better they arent going down vs arent going up. If you use the witch on the back doors to operate them do they work? My front right window stopped going down from the master window switch. The passenger switch could make it go down though. I ended up replacing my master switch and everything worked fine again.
        i gotta check it out because its wierd the front passanger and driver windows go down but the rears dont work with the master switch or the switches in the back. maybe it is the master switch but im gonna check and see if theres a fuse
        WHITEONWHITE
          I got a problem with my windows too.
          Only its my rear passenger window that doesnt go up with the master switch. I can use my controls to make it go down, but I have to reach back to the switch on that door to make it go back up. Is this a master switch problem?
          PSN
          Vash744
          MRT 1992 EX Coupe "The Jerk"
          2009 Subaru Impreza 2.5i Premium Hatchback
          2008 Honda Fit Sport (Totaled out - Death by fallen tree)
          1993 CB7 Sedan LX (Totaled out)
          1991 CB7 Sedan EX (Dead and Junked)
            too bad i just junked my parts car with master switch coulda ave it to someone
              Yes
                I found the fuse box diagram im gonna check my fuses tommorow but there is fuses for the rear windows
                WHITEONWHITE
                  Don't mean to thread jack but I also have window issues, but not with the switches.
                  My rear passenger window will not go all the way up. I can let it down and back up but it always stops about 1/4" from the top of the window sill. Not a major problem but it is annoying to get rain on the seats and my stuff if I happen to have something on that side.
                  Also, my driver's window goes up all the way but once it gets to the top the window cocks a little at an angle and leaves a crack in the top right of the window. Again, not a major problem except for rainy days.
                  Any help would be appreciated.
                  We are all ricers, it just depends what flavor rice you are.
                  Minitrucker by heart, CB7tuner by coincidence.
                  My For Sale Thread
                  Bowling Pin Shift Knobs
