car throws cek on randomly and wont start
    so 4 the past 2 years my car has been randomly throwin the check engine light on and wont start. After waiting a few minutes it will start and run perfectly fine. Any ideas on a solution 2 fix this problem?
    pull the code next time it throw....
    Members Ride sold...
      Unless the problem is fixed, or you've reset your ECU, the code should still be stored in the memory.
      But, my guess would be the main relay, or the ignition output sensor (a white box under the steering column.)
        main relay I would almost bet money on it....
        WAGONS
        94 ce1- f22b DOHC auto swap, ROH 11.1" 99 cl brakes, rear disk swap, dual plenums, aem cai, tein ss, OEM stanley one piecers, OEM stanley yellow fogs, OEM 96 Oddy roof rack, Yakima basketcase, some wheels, some tires.... etc.
          first thing you need to do is get the code. then go from there. later.
          Avoiding dirt at all costs
