Does anyone know if the cb7 has some kind of a voltage regulator or anything like that which operates when the car is running? I know if I connect my car to a battery charger so I can listen to music for a long time while messing with stuff on the car the voltage on my meter will read over 14 volts, but if I turn the car on, the meter will always drop to about 13.5 volts (the meter's off by about a volt so it's not low). I'd think the reading would stay above 14 volts with the charger still connected but it doesn't so I just wonder if there is something on the car or in the ECU that limits the voltage when it's running? Thanks!
What controls car's voltage?
dont think so... do u have a HO alt or rewound one? with mine running and 2 batts and the HO alt i keep a 13.9 which is awsome but i only have a 300.4 running right now and thats also with lights and blower on.
if you got 2 batts and no HO or rewound alt thats a load on the alt that only does 80amps max.
I have a rewound alternator. I wanna add an HO alternator so I'll have plenty of power, but I'm not sure what kind to go with. I'm just curious why the voltage on my meter reads lower with the car turned on. If my meter were accurate it'd probably show about 15 volts with the charger on and car off, 14.2 or something with the car on and both the alternator and charger running. That's why I wonder if there's something in the car that regulates the voltage when the car is running.
It'd be so much easier if I had my car during the week. I think the charger probably reaches close to 15 volts, and the alt goes up around 14, I don't have a real accurate meter to tell. I just know the voltage drops when the car is on so I wonder why. And it's common for people with High Output alternators to use an external regulator and charge them at 15 volts so it shouldn't hurt anything too much.
Originally posted by Sarthos View PostDoes anyone know if the cb7 has some kind of a voltage regulator or anything like that which operates when the car is running? I know if I connect my car to a battery charger so I can listen to music for a long time while messing with stuff on the car the voltage on my meter will read over 14 volts, but if I turn the car on, the meter will always drop to about 13.5 volts (the meter's off by about a volt so it's not low). I'd think the reading would stay above 14 volts with the charger still connected but it doesn't so I just wonder if there is something on the car or in the ECU that limits the voltage when it's running? Thanks!
all cars should be at 13.8 to 14.4. if your keeping consistant at that rate your ok, but if u want your car to last longer while the car is off...get a deep cycle battery.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Yes there is a voltage reg., pretty sure it's an internal in the alt. Also if you want to play music for a while without drainging the battery they make a converter so you can run it off a wall outlet.
"The Turtle"
DD/Trail Rig/Mud Bug
