so i have 2 Alpine Type R subs and they are dual 2 ohm subs
the amp is a Rockford Fosgate P6002 and the specs on that are
continuous power 150W x 2 @ 4-Ohms RMS
300W x 2 @ 2-Ohms RMS
600W x 1 @ 4-Ohms bridged RMS
so i know i can series wire each sub and run 4 ohms to each channel on the amp
but i want to push as much power from the amp as i can and the only other way i thought to wire it was parallel wire each sub so they are 1 ohm each then series wire them so in the end it will be 2 ohms but that wont work because the amp says 600W x 1 @ 4 ohms
so can i get some advice?
