turning on amp manually
    my beloved sound system was recently stolen (mostly). they took my subs, amp, cap and head unit, but left my 4 channel amp and speakers, im guessing someone scared them off. anyways, im too depressed about it to go and spend more money on car audio , so i want to know how to manually turn on my 4 channel amp so i can just hook up my mp3 player to the rca inputs on it.
    12v feed on a switch . or you can run a wire from something that turns on with the ignition. To the remote line in on the amp. Or you can just use the remote wire on the radio wire harness
      Options A, B, C, D provide auxillary power. Uses a normal spade terminal.
      Option D is a constant from the battery, don't use that.
      I can't remember the other exactly, but one switches with the headlights, one switches with the ignition switch and I haven't figured out the last.
      You can use one of these for the ant/power trigger on your amp.
      Bart: What's your name?
      Jim: Well, my name is Jim, but most people call me... Jim.
        remote wire is probably your best bet. its very easy to wire up and you dont have to worry about turning it on. the wire at most would cost you about $8 lol
        I breathe down shit so hard, you could see sound.
          12v line straight from battery to a switch, then remote wire to other side of switch. Mine is ran that way.
            Where is the amp?
            If its under a seat, just take a switch and a short amount of wire.
            One wire goes to the amp's POS then switch, the other goes from switch to remote input.
            Just remember to turn it off.
            From what I remember, plug C is headlight controlled.
            Plug A is key controlled.
            Your man for wiring solutions!
            CB7Man's Coupe H22 Swap
            CB7Man's Sedan Resurrected From The Dead
