okay so i have had a 4 chan infinity amp powering all my speakers and subs. I have been to cheap to get a amp for just my sub. anyways i just ordered one tonight.
The subs I have are the Kicker CVR 12" in the kicker box. specs for one sub as follows:
# 12" subwoofer with dual 4-ohm voice coils
# injection-molded polypropylene cone
# ribbed Santoprene rubber surround
# suitable for marine use
# power handling: 50-400 watts RMS (200 watts per coil)
# 800 watts peak power handling
# frequency response: 25-500 Hz
# sensitivity: 86.7 dB
# top-mount depth: 6-1/4"
# sealed box volume: 1.0-4.6 cu. ft.
# ported box volume: 1.75-2.25 cu. ft.
# Recommended Q-Logic Box Type: 1, 2, 3
# warranty: 1 year
# Want more peace of mind? Extended Service Plans Ava
The amp I got is:
* SPECIFICATIONS
o Amplifier Class : Class D
o Number of Channels : 1-Channel
o Maximum Power : 4000 Watts
o RMS Power Output @ 4 Ohms : 1200 Watts x 1 Channel
o RMS Power Output @ 2 Ohms : 1700 Watts x 1 Channel
o Bridged Power : N/A
o THD (Total Harmonic Distortion) : 0.5%
o Signal-to-Noise Ratio (dB) : 100dB
o Frequency Response (Hz) : 15Hz~150hz
o Built-in Crossover : N/A
o Subsonic Crossover Frequency : 20Hz-50hz
o Low-Pass Crossover Frequency : 40Hz~200Hz
o Bass Boost : 0dB~18dB
o Bass Remote : Yes
o Fan Cooled : N/A
o Fuse Rating : 40A x 3
o Dimensions (Width x Height x Depth) Inches : 13.77" x 8.26" x 2.16"
o Approximate Weight : 10.3 LBS
o Warranty Information : 1 Year Warranty
Will this power it perfect and make them hit hard? let me know this is what the guy on the phone said would work. but im not sure about the ohms of the subs, could be 2 or 4
# warranty: 1 year
The amp I got is:
* SPECIFICATIONS
o Bass Remote : Yes
o Fan Cooled : N/A
